TC48DA Steering Problem Fixed!
   / TC48DA Steering Problem Fixed! #1
IH3444
Hello, I'm here again to report on my "steering problem". I did some loader work this weekend with the TC48, and now with my reinforced ballast box loaded with a bit over 1000 pounds of lead bricks, and steel blocks. I'm very happy to report that the tractor steers fine, even with a heaped bucket of either #57 stone, or earth. I must also report that Bad Dog is absolutely right, this loader is extremely powerful, and I believe that a bucket 30% larger could be hung off the front, and the tractor would still fill it, and pick it up. I am impressed with it's ability to heap the bucket up, lift it, and travel around without even the slightest problem. I purposely stopped the tractor and worked the steering to see if the front R4s would respond. They did, and it steers like the IH3444. I guess just some serious ballast was needed at the rear, along with the loaded tires. The tractor is a joy to drive, and doesn't work me as hard as the IH3444. I am still going to cast a rear concrete block in the 1500-1800 pound range, but for now this 1000 pounds is working great. /forums/images/graemlins/grin.gif
   / TC48DA Steering Problem Fixed! #2
It's good to be right!
Be careful with that loader or you'll be bending your lift links, now that you have enough ballast to hold what the loader can handle. The lift links are the next weak 'link' in the chain.
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
2025 REDELIFT CPD25-XD4 FORKLIFT (A52576)
2025 REDELIFT...
2017 INTERNATIONAL PRO STAR (A52472)
2017 INTERNATIONAL...
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
