TC48DA PTO lever is stiff
   / TC48DA PTO lever is stiff #1
chevyjam2001
Snover, MI
2007 NH TC48da
I picked up a 2007 tractor last year after the PTO on my old Massey 85 quit working. Ever since I got it the PTO lever has been very stiff. I only used it a little bit last fall but in order for me to get it to disengage and move back to the locked position I had to use 2 hands. I would have expected it to operate much smoother than that. It made me miss the old Massey. I went to use it for the first time this past weekend and the light on the dash would come on but the PTO will not engage. If the PTO safety switch is bad would that also keep the PTO from engaging. I couldn't get it started so my car mechanic buddy came out to take a look. I have a bad cable so I wasn't getting power to the starter but even after that was corrected it still wouldn't start. He figures there is a bad switch somewhere but was going to have to find a wiring diagram to figure out where they were at and how many there are. We got it started by jumping it directly at the starter. I was going to run my tiller while I had it running but when I engaged the PTO I got nothing.
   / TC48DA PTO lever is stiff #2
That stiff-lever seems to afflict those Boomers. I think most are cured by some penetrating oil and moving the lever, repeat forever. Note the penetrant needs to have some lube qualities: not WD40.
Jim
Unfortunately it wasn't a quick or easy fix. I had to consult a mechanic and it was the hydraulic control valve under the seat that was seized up. The part alone is $895 because you have to buy the entire assembly. They don't sell a rebuild kit. :(
   / TC48DA PTO lever is stiff #4
They, New Holland, DO make a repair kit for the PTO valve. See parts sheet. (07.01.01) - PTO CONTROL VALVE, parts list item 12, part no. SBA340293763, for about $120 on Messick's site.
The dealer to him it wasn't available anymore😠
He said that was an O ring kit and I needed on of the cylinders/pistons. Mine was broken in half
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
Margaritaville Miniature Decorative Truck (A55853)
Margaritaville...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
2010 GMC Seirra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Seirra...
