TC48DA Is it a deal?
   / TC48DA Is it a deal? #1
rah6965
Carthage/Sanford North Carolina
New Holland TC48DA
I found a 2005 New Holland TC48DA, 4WD with a 18LA QA loader with R4 (fluid filled) tires and only 32 hours. It has hydraulics up front with joystick for a 4in1 type bucket, but the attached bucket is a 84in. material bucket. It has the standard 12F/12R syncro transmission. It has 10 months of warranty left. I've negotiated a $19,000 offer and will probably get it. It's the best deal I've found in late model 45-50HP tractors in Green, Blue, Orange or Red. I'm new to the tractor world and also wondered if the 84in. material bucket was a little big for that tractor/loader? Any comments would be appreciated. Also need to know how much weight is normally added with 4 fluid filled tires?
   / TC48DA Is it a deal? #2
Congrats on your TC48 . The tractor loader will handle a light material or heavy duty NH 72" bucket . This is the setup that should have been from the factory dealer. 84" is to large for the loader unless our moving really light material.
   / TC48DA Is it a deal? #3
They recommend 800 pounds of fluid for each rear R-4 tire 75% fill + some extra weight in a weight box . I would get a owners manual there is a weight chart in the back . Is the 84" bucket the only one avalable with the tractor ? I guess it depends on the heaped and struck capacity . The 72" NH heavy duty bucket is around 12.4 cu-ft or 0.459 cu-yds accdoring to the owners manual.
The Tractor takes alot of weight because of the lift capacity . But they seem to be stable at least mine is .
The 84in. bucket was added by the dealer when new. I was told it was $800 for the bucket. I guess I will just see how it works for me. I appreciate the info about the loaded tire weight. I was trying to determine my total weight for a trailer to transport it. I don't think most people load the front tires, but the original owner decided to or was talked into it by the dealer. Thinks for the feedback. If I calculated it corretly, it looks like the tractor FEL and loaded tires put the tractor over 7K. pounds.
   / TC48DA Is it a deal? #5
Yes, you'll be way over the limit on the average 7k lb gross weight trailer. You'll have to move up to a 10k gross weight or more. My TC45D with loaded tires, FEL, and boxblade is over the limit on my 7k lb trailer, so I'm sure your TC48 would also be.
I have to agree with FULLPULL about bucket size. These big buckets are great for moving materials, but they are too big for digging. For digging, I really like my 5' bucket on my tractor. I have both a 5' and 6' bucket for my TC45D. Your TC48 should handle a 6' bucket better than that 7' one. 7' wide is a huge chunk of dirt to cut in native soil. Also, if you want to dig up a stump, you have to dig a huge hole. That wastes your time and effort. The guys with backhoes laugh at us when they see us digging out a stump with our big wide loaders.:eek: :rolleyes:
I think you have a great price on that tractor. I'd snap it up in a heartbeat.:)
   / TC48DA Is it a deal? #6
It sounds like an excellent deal to me as well. I've had my tc 48 for almost four years now and am very happy with its performance.
   / TC48DA Is it a deal? #7
Delivery weight 4158 lb +1600 or so for fluid approx 1200 lbs for the loader add 200 for fluid . I dont know if the tires are included in the deivery weight . From what i see some where from 7100 to 7500 lb is close. Depending on options . 19000. seems like a good price . I would check what the warranty covers .
I really appreciate everyones feedback. I've decided to get the tractor this week. The 84in. bucket is all it comes with, so I can trade it in for a 72in. or try and find a smaller QA bucket and use the 84in. for loading light material. What length trailer would work best for the TC48D with FEL. I may want to haul my 6ft. cutter sometimes too. I figure it will take a 10K Gross trailer at 16ft. just for the tractor and FEL. I would need 24ft. to haul the cutter behind it.
   / TC48DA Is it a deal? #9
I think a 24' bumper-pull trailer is pretty rare. It seems to me that 20' is about the longest I normally see. I could be wrong since I haven't looked at new trailers in a long time. I see a lot of 24' or larger gooseneck trailers.
I believe you could put that tractor and cutter on a 20' trailer if you curl the bucket all the way under and let the cutter hang off a couple of feet. I don't know anything about the laws in your area and if that would be allowed. Obviously a 24' trailer would be best.
   / TC48DA Is it a deal? #10
That is a good price. Buy it. If you dont want it, I would be interested.:D
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2008 Sterling Bullet Utility Truck, VIN # 3F6WK76A88G352277 (A51572)
2008 Sterling...
UNUSED AGT MX MRT14 STAND ON SKID STEER (A51247)
UNUSED AGT MX...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
TMA (A49461)
TMA (A49461)
