TC45DA Whining while in forward
   / TC45DA Whining while in forward #1
Yupneck
Powhatan VA
2004 New Holland TC45DA
Morning all,
I'm hearing a whining noise when going forward only. I have changed rpms and that only changes the noise level.
Any ideas?
   / TC45DA Whining while in forward #2
It is normal for a HST to whine. That is why I got a CVT for mowing.
I bought this tractor in August, This is not the normal whine from the HST, it is a higher pitched whine.
Also, the further I push the forward pedal the more it whines.
I'm in the process of ordering all new filters (hydro, air, oil) to do a full fluid change to see if that may help (needed anyway).
   / TC45DA Whining while in forward #5
Just make sure you use the correct fluid for your temps. Sounds like a viscosity whine? Good luck.
Jim
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
flooring (A55758)
flooring (A55758)
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
Husqvarna 46in Riding Mower (A56859)
Husqvarna 46in...
