TC45DA Whining while in forward
   / TC45DA Whining while in forward #1
Yupneck
Powhatan VA
2004 New Holland TC45DA
Morning all,
I'm hearing a whining noise when going forward only. I have changed rpms and that only changes the noise level.
Any ideas?
   / TC45DA Whining while in forward #2
It is normal for a HST to whine. That is why I got a CVT for mowing.
I bought this tractor in August, This is not the normal whine from the HST, it is a higher pitched whine.
Also, the further I push the forward pedal the more it whines.
I'm in the process of ordering all new filters (hydro, air, oil) to do a full fluid change to see if that may help (needed anyway).
   / TC45DA Whining while in forward #5
Just make sure you use the correct fluid for your temps. Sounds like a viscosity whine? Good luck.
Jim
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
HYDRAULIC SKID (A52472)
HYDRAULIC SKID...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A52472)
2014 AMERITRAIL...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
