TC45DA Cruise Control Troubleshooting
   / TC45DA Cruise Control Troubleshooting #1
penfrydd
New Holland 45
I've operated farm tractors for 62 of my 70 years. This is the first hydro trans that I've had. I didn't even know the thing had cruise control when I bought it (used). I must say, it's real nice to have for mowing pastures. However, it stopped working last year.
I checked the fuse first thing, but that is okay. Anybody have any idea on the next logical steps or the most likely issue?
   / TC45DA Cruise Control Troubleshooting #2
Mine quit a while back. I had to replace the switch. I could tell it went bad from the feel, wouldn't stay down when I pressed it. Messick's has it for $36.23, 7 in stock.
   / TC45DA Cruise Control Troubleshooting #3
Another possibilty: If it's the same cruise system as my TC33D then you might check and adjust the contact points underneath by the linkage. I know I found quite a few threads with pictures and detailed directions.
   / TC45DA Cruise Control Troubleshooting #4
I has the same issue on my TC33D and the brake switch needed to be adjusted. When pressing the brake it opens the circuit and drops power off the magnet that hold the rocker pedal in position the desired position.
Kubota 48in Loader Bucket (A50322)
Kubota 48in Loader...
Portable Fuel Tank (A50515)
Portable Fuel Tank...
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
2016 Bobcat E85 Midi Excavator (A50322)
2016 Bobcat E85...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
John Deere A Tractor (A50514)
John Deere A...
