TC45DA Attachments
   / TC45DA Attachments #1
wesv82
New Holland TC45DA
Aside from a grapple has anyone found any hydraulic FEL attachments for the TC45?
I would love to have a concrete mixer, but it looks like the flow rate required is too high.
   / TC45DA Attachments #2
I believe that machine should have about a 9-10gpm flow rate from the remotes? That's just below the low end of a standard flow skid steer.
For a concrete mixer I wouldnt worry about it to much. What's there spec for needed flow?
   / TC45DA Attachments #3
I, recently, rented a post hole auger designed to go on a skid steer. Worked fine on the front of the TC 40 although it turned slowly. Much better than the 3pt auger I own. I also have a bale grabber for round bales of hay. Works fine, might want a rear weight, won't lift the heaviest sileage bales well. I also use the rear remotes for a variety of hay implements: mower, baler, tedder,etc. I have a Stump Grapple on mine. Best attachment I ever bought. Dig out rocks, stumps, pick up tree-length logs, etc.
2017 Taylor-Dunn BO24836 36V 4-Seat Electric Utility Cart (A49346)
2017 Taylor-Dunn...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
DMT Corp DMT-25L Diesel Generator (A49346)
DMT Corp DMT-25L...
2000 Ford F650 Flatbed TMA (A49461)
2000 Ford F650...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
