TC45D Tie Rod end
   / TC45D Tie Rod end #1
missesalot
Brockport NY
tc45d
The left outer tie rod end is supposed to have a grease nipple, its missing. The hole is packed full of mud. Whats the best way to go about dealing with this? Should i just replace the end, 75 bucks, or is there a way i can clean that out, or force the dirty grease out through the boot without risking leaving abrasive in there. Or doesn't that matter? Thanks in advance.
   / TC45D Tie Rod end #2
I would get a small pick and pick the crud out, then blow with air and put a new grease zerk in. I have sheared a couple off and needed an easy out to get the threaded part out. Good luck.
   / TC45D Tie Rod end
shoot, now i'm wondering if thats the problem. would make it easier regarding the crud. thanks for the reply, good idea.
   / TC45D Tie Rod end
how can I find out what size zerk that is? I'm thinking the only thing i can do is take the one from the other side out and try to match it. NH doesn't list it on the parts diagram.
   / TC45D Tie Rod end #5
Does anyone know the size of the zerk on the tie rod ends for the TC45D?
I know the hex itself on the zerk is a 7mm ... possibly a 9/32 if standard
Does new holland use metric or standard zerks?
Edit: Looks like the tractor is metric and the loader is standard
https://www.tractorbynet.com/forums/new-holland-owning-operating/100594-zerks.html?highlight=Zerk
I’d still like to know the exact size of the tie rod end zerk if anyone knows for sure or has a part number. This zerk isn’t listed on the parts diagrams for new holland
Edit 2: I’m thinking the tie rod end zerk is m6x1 ?
   / TC45D Tie Rod end #6
Zerks on the tractor are metric, if you have a loader those zerks will be standard. M6-1 sounds correct for your tie rod ends.
   / TC45D Tie Rod end #7
Thanks Rick
You were correct, m6x1 is the correct size for the tie rod ends
I just picked some up and installed them the other day
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A57024)
2018 John Deere...
(2) GOLF BAGS W/ CLUBS (A54757)
(2) GOLF BAGS W/...
2017 DRAGON ROLL OFF TRAILER (A55745)
2017 DRAGON ROLL...
WORK BENCH (A55745)
WORK BENCH (A55745)
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
