TC45D Rear/Mid PTO Screech
   / TC45D Rear/Mid PTO Screech #1
Vinto
I have a TC45D under 300 hours that has been used about 150 hours with its mid PTO and a mid 84" deck. There is a screeching noise in the PTO area. I first noticed the problem using the Rear PTO post hole digger augering holes for my vineyard this spring. The gearbox area between the rear and mid PTO would make a screeching noise when lateral force was applied to the PTO shaft.
I have not had the time to trailer the tractor back to the dealer but was bushhogging today to clear a path to install new fence and the same noise started when the rear mower pto was disengaged.
Sounds like a bad bearing in the area between the mid and rear PTO area. Anyone have a similar problem or ideas.
Vinto /forums/images/graemlins/confused.gif
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52748)
2022 MAXXD BD14...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
