Price Check TC45D price & motor question
   / TC45D price & motor question #1
davecrave
Just tested a 2002 TC45D with hydro, 17LA loader w/quick attach 72" HD bucket, AG tires, super-steer, rear remotes, wheel weights, loaded tires, block heater, rear work light, and grill guard. They are asking $18000. Is this a good price?
Also, this has happened on another used TC45D I tested, the engine at idle accelerates up and down. Is this normal for this engine? I currently have a NH 1630 and the idle is at a constant speed.
   / TC45D price & motor question #2
I paid 1500 less, but had R-4's, no wheel weights, no front guard, 1200 hrs, and no QA. Yours sounds a bit better than mine, but I am glad I got mine.
Chris
   / TC45D price & motor question #4
My 2002 TC40D is steady also.
   / TC45D price & motor question #5
Pretty good chance the low idle speed is below spec and the governor is "hunting". Bump the throttle up about 50 rpms and see if it settles down.
   / TC45D price & motor question #6
I agree with RickB. I was going to ask what rpm the engine is idling at. Mine will hunt a little when I first start it, but it becomes steady as soon as it warms up and the idle settles out at 1000 rpm. If the tractor is below 1000 rpm, bump it up a little and see if that doesn't make it smooth out.
...and the price is very good. That's a $24,000+ tractor when it was new.
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Dodge Journey Van (A59231)
2015 Dodge Journey...
Mini John Deere Truck (A55853)
Mini John Deere...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
John Deere 6110M (A60462)
John Deere 6110M...
