TC45d only goes 5mph
   / TC45d only goes 5mph #1
missesalot
Brockport NY
tc45d
Hey all, Continuing to work on my new to me 45d, last night I drove it on the road to see how close I could get to the top speed in the manual, 13.6MPH. In range II I could only get it up to 5mph. Seems like i must be doing something wrong. Tell me I'm doing something wrong :)
   / TC45d only goes 5mph #2
I learned from folks here that there is also an electronic speed range switch. Should be a switch on your joystick and a switch on right side of seat. Rabbit and turtle, it defaults in turtle mode. Switch thant and put manual range lever ib two and youll be moving
ok i didn't realize that the buttons on the stick were relevant to tractor speed, i thought that was about the flow for the loader hydrolics. I had the rocker switch in high, i thought, but didn't play with the buttons on the stick.
what else could this be? is there anything else that could be causing this?
   / TC45d only goes 5mph #6
I moved it out of 4x4 auto and into 2wd and it goes 9mph. I figure it's due to the weight of the loader and back hoe
   / TC45d only goes 5mph #8
Is the tranmission Hydrostatic or synch shuttle? That tractor should have enough power that the loader and backhoe would not matter. So it drives faster out of 4x4 vs. 2x4? that doesn't seem right.
Do you know if it original tires? Front tire: 5.50x16 Rear tire: 13.6x24???
Yes it's hydrostatic. Yes stock tire size
   / TC45d only goes 5mph #10
Make sure your pedals are moving all the way down.
Does it go 5 mph in reverse also or does it go faster?
On my 45. The linkage gets bound up and have to lube with spray lube. I've also had a stick bend the main shaft and cause cam plate to not move correctly.
With tractor off wheel chocked. Move pedals while under tractor and look for sticks in linkage area.. look for bent cam plate. Check over and then lube
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
2018 Gatormade 20+5 Gooseneck Trailer (A52748)
2018 Gatormade...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A52748)
UNVERFERTH 330 -...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2009 INTERNATIONAL PRO STAR (A52472)
2009 INTERNATIONAL...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
