fishpick
Platinum Member
The new to me TC45D is an amazing tractor - and every time i get on it and use it I discover more things to like.
One thing I figured folks here could answer for me is something I have seen I'm not a super fan of. I have th NH FEL on this tractor with the QA plate and bucket. No issues with lifting or curling the bucket - super capacity and the tractor moves a full load of gravel like there's nothing up there... however, when I dump and then angle the bucket down to grade in reverse the bucket has about 3" of "slop" in it. SO - I curl down to give me the edge, lower the bucket into the gravel pile I just dumped and then step on reverse to grade it out... the bucket will - without me touching the joystick - roll about 3" forward making the edge go away and not be very effective at grading things out. I can then re-adjust the bucket edge and it will hold...
So - just checking to make sure this little bit o slop is normal.
I remember a Deere backhoe I used once had this sort of thing.
