TC45D driveline play
   / TC45D driveline play #1
yellowdog
I notice a slight "klunk", that sounds like driveline play in the HST system or mechanicals when using my TC45Ds frontend loader. The sound occurs when going from foward to reverse or vice versa. I would like to know if anyone else has noticed this on their machines. It's still under warranty for about 8 more months, so I want to see if its a problem thats specific to mine or if its normal, before I approach my dealer.
   / TC45D driveline play #2
I do notice a slight klunk when using my loader but I'm pretty sure that it is due to the small amount of play in the loader mounting frame (the pins that you take out to remove the loader). You might also make sure that all your loader bolts are tight (front axle mounting bolts too). Can you make the drive line klunk without using the loader?
Peter
   / TC45D driveline play #3
Y-dog, I agree with Peter. I have a clunk in my loader from somewhere around the mounting pillars. I suggest also that you do a check of all the bolts mounting the loader sub-frame and especially the ones for the pillars. My clunk is only occasional and when I am working the loader pretty hard.
1989 21' Sun Ray Boat (A50515)
1989 21' Sun Ray...
City of Lakeland (A51691)
City of Lakeland...
E-Z Trail Head Cart (A50514)
E-Z Trail Head...
Polaris ATV (A50324)
2003 Doyle Semi Horse Trailer (TITLE) (A50774)
2003 Doyle Semi...
2004 30ft S/A Scissor Pontoon Boat Trailer (A50324)
2004 30ft S/A...
