TC45D driveline play
   / TC45D driveline play #1
yellowdog
I notice a slight "klunk", that sounds like driveline play in the HST system or mechanicals when using my TC45Ds frontend loader. The sound occurs when going from foward to reverse or vice versa. I would like to know if anyone else has noticed this on their machines. It's still under warranty for about 8 more months, so I want to see if its a problem thats specific to mine or if its normal, before I approach my dealer.
   / TC45D driveline play #2
I do notice a slight klunk when using my loader but I'm pretty sure that it is due to the small amount of play in the loader mounting frame (the pins that you take out to remove the loader). You might also make sure that all your loader bolts are tight (front axle mounting bolts too). Can you make the drive line klunk without using the loader?
Peter
   / TC45D driveline play #3
Y-dog, I agree with Peter. I have a clunk in my loader from somewhere around the mounting pillars. I suggest also that you do a check of all the bolts mounting the loader sub-frame and especially the ones for the pillars. My clunk is only occasional and when I am working the loader pretty hard.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2019 Vengeance Rogue Toy Hauler Camper (A50514)
2019 Vengeance...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2014 Ford Transit Connect Van (A50323)
2014 Ford Transit...
SAKAI SV510 SMOOTH DRUM ROLLER (A51242)
SAKAI SV510 SMOOTH...
