Oil & Fuel TC45D Diesel Leak
   / TC45D Diesel Leak #1
bucksnort1
North Carolina
New Holland TC45D
Good morning all.
My TC45D has developed a diesel leak which seems to originate from the injector manifold. I've been observing this for several months now and here's what's strange: the leak only seems to occur when the engine is not running and the fuel petcock is left on. It takes several hours for the leak to begin but it will literally drip fuel on the ground. In this case the engine will be very difficult to start as the engine is flooded with diesel. Once started the engine runs fine and I can not detect any leakage. My work-around is to always remember to turn the fuel off when I park the tractor but I would like to understand/address the root cause.
Has anyone else seen this problem or have any ideas as to what might be causing the leak?
Thanks for your thoughts!
   / TC45D Diesel Leak #2
Your pump is most likely leaking from the o-ring that surrounds the individual pumping elements. Unfortunately you cannot service the pump without a 5-point 9mm socket.
Your dealer may not have the tools or expertise to service your pump, you may have to find diesel pump and injector shop.
Mike
2018 Freightliner M2 106 Medium Duty AWD Altec AA55 56ft Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
Killbros 260 Seed Conveyor (A56435)
Killbros 260 Seed...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
ALLISON TRANSMISSION (A55745)
ALLISON...
