TC45 Won't Start
/ TC45 Won't Start #1
pesh104
Ford New Holland TC45
Ford NH TC45 - Can I try pulling it to get it to start? Tried everything including all bypass' etc. Any ideas would help. Thanks
/ TC45 Won't Start #2
give us more info. Cranks but doesnt start, no crank, what?
/ TC45 Won't Start #3
First thing to check is the seat switch. By pass it and go from there. If its a hydro Netural is not always on the mark. move the lever around.
Brake safety may or may not be working.
You didn't say if it cranked or not. Seat switch will let it crank, but not start.
/ TC45 Won't Start
Turn the switch and nothing, not a thing. Battery is good. Bypass safety switches, haven't tried bypass of the ignition switch because I don't know how.
/ TC45 Won't Start
It won't crank and isn't locked up. Tried seat switch, brake switch and power take off switch. Checked wire going into neutral switch.
/ TC45 Won't Start #6
Remove the phllips head screws on your instrument panel and carefully lift it out of the dash. On the left side, pull the #2 fuse and see if it is blown. Replace it with a 10 amp or self-resetting circuit breaker for a long-term fix.
This may not be your problem, but I'd bet it is. I'd bet you a big ol' greasy hamburger if I weren't on a diet.;)
/ TC45 Won't Start
Ok, so I'm posting for my dad, he is going now to check the instrument panel. Thanks
/ TC45 Won't Start #8
Well, the fuses are below the instrument panel on the left. I didn't make it clear that they are not on the instrument panel.:eek:
/ TC45 Won't Start
Thanks, We found a fuse that is out but he was never given a manual to tell if that's the one we're looking for so he ran to the auto parts store to replace it. Will post the result as soon as he gets back.
/ TC45 Won't Start
Thanks Jim! That was it. He said he owes you a big fat greasy cheeseburger as soon as you're off your diet.
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
