Tires tc45 tire sealent
   / tc45 tire sealent #1
h10doc
Collierville,TN
Tc45D
I have a TC45 with agi. tires does anyone know how much sealent i need to buy and how many oz. in the front and rear tires? Thanks
   / tc45 tire sealent #2
Here is an Application chart from Multi-Seal . Even if you not using Multi-Seal I would think this amounts would be ok to use, it gets you in the ball park.
Hope this helps.
  • ApplicationCharts.pdf
   / tc45 tire sealent #3
P.S.
I am sure that this chart already has calculated and has you putting more sealant than needed.
But, my friends refer to me as CAPTAIN OVERKILL, meaning just that, I tend to think a little does a little good , then a bit more will be even better.
Case in point , A TC45 would have been all that was needed for our property, but I wanted more loader capacity, so I looked at the TC48 , but if I'm going to the 48 then may as well go to the 55.
SO
I have purchased a TC55 with Ags , hopefully delivered this weekend. I have on order 6 gallons of Multi-Seal , even though the chart says 4.75 gallons will be suffcient for all the tires . I am going to over dose them by 16oz, in case a puncture allows some to escape before sealing.
   / tc45 tire sealent #4
deerhunterf350 said:
P.S.
I
Dear CAPTAIN OVERKILL: What kind of tranny?
Bob
   / tc45 tire sealent
deerhunterf350 were do you get the muti seal and how much cheaper is it then slime?
   / tc45 tire sealent #6
Bob
TC 55DA
12x12 SSS MECH Tranny
3 Rear Remotes
18LA Loader with quick attach , with HD bucket w/ bolt on cutting edge
Yeah I know, a true CAPTAIN OVERKILL would have been the EHSS Tranny, but the dealer had the tractor on the lot. And let me have the set up with bill of sale for $24,600.00 . To prove that it is not a Stolen Machine
   / tc45 tire sealent #7
Bob
TC 55DA
3 Rear Remotes
   / tc45 tire sealent #8
Multi-Seal is a lot more expensive than Slime. It can be purchased on-line. If you want to purchase some and can't find a local dealer let me know and I'll send you a link to the dealer that supplied me with 5 gallons.
   / tc45 tire sealent #9
TC 55DA
3 Rear Remotes
Nice machine, and BTW, good of you to admit that you should have gotten an EHSS in order to keep the name "CAPTAIN OVERKILL " :D
The TC55DA is a very nice machine. Nice HP. And the extra weight will help if you ever decide to plow.
Bob
(INOP) RHINO 1310 ROTARY CUTTER (A52708)
(INOP) RHINO 1310...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A58017)
2016 FREIGHTLINER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
