Tc45 rear remote port identification
   / Tc45 rear remote port identification #1
crbailey
Browerville mn
new holland tc45
Hi all new to forum. can anyone identify the three hydraulic ports behind right rear tire where the factory kit goes I want to milll a plate to attach a two spool hydrolic valve a hundred bucks is a lot better than the thousand it would cost for the two remote kits from new Holland
   / Tc45 rear remote port identification #2
You might look at their loader or backhoe install kits. Kubota has a plate with threaded fittings for loader installs. I ordered one (just the plate) and it was under $50 with the orings to seal it.
Aaron Z
   / Tc45 rear remote port identification #3
How hard can this be? You already have power beyond available at the diverter valve, but should you choose not to go there and fabricate your plate instead, you can identify the ports you mentioned easily enough. All you need is a rubber tipped air nozzle and compressed air. Fully lower the lift arms. Remove said plate and expose the ports. If you bump the starter, oil should flow from the pump's supply port. If you introduce air pressure to this port, it should go nowhere. Remove the filler cap and move the lift control lever to about midway or so. Then introduce air pressure to one of the other ports. With one(sump return) air will be heard escaping through the filler opening. With the other(pressure in), the lift arms will rise. Now you know which is which.
Forgot to mention that I have a fel installed that's why I thought about drawing power from that plate as they do with the factory remotes as stated source is easy turn key and see were oil comes flying out if power beyond and tank are the ones I'm not sure of if there is a better way to feed that remote valve I would love to hear it but please let leave the sarcasm for my wife thanks!
   / Tc45 rear remote port identification #5
Take a couple of pictures of the plate, one close up, one showing the lines going into it.
If you can, look at where the lines form the plate go into the loader valve. Look for markings like P, T, PB, or In and Out cast into the valve.
What year is your TC45?
Aaron Z
2019 Chevrolet Tahoe (A56859)
2019 Chevrolet...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2014 GENIE Z-60/34 BOOM LIFT (A52709)
2014 GENIE Z-60/34...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56435)
Kuhns AE10 Small...
