TC45 Hood Latch
   / TC45 Hood Latch #1
Fullthrottle
SC
NH TC45
Any of you Boomer owners had hood latch problems? Went to pop the hood and it won't release. The latch will move a 1/4", but won't release. Thanks in advance for any help..
   / TC45 Hood Latch #2
Had that happen on my 29D. Not a good feeling ...
Shot some WD-40 into the latch and fiddled with the hood latch and hood till it finally let go. Now when I'm in the barn, I regularly open and close the hood and spray it with some teflon lube monthly. It's been OK since.
Good luck - hope you don't need the BIG pry bar ...
Brad in NH
   / TC45 Hood Latch #3
My 25D was hard to unlatch initially. I had to push down on the front of the hood while pushing the latch over. Not easy to do while leaning over a FEL arm. /w3tcompact/icons/laugh.gif It unlatches OK now.
   / TC45 Hood Latch #4
Had the same problem with my TC35D...once. I had to wiggle the hood side to side to release the catch. Never has bound up again. Maybe just that the hood closed a little twisted.
   / TC45 Hood Latch #5
I had the same problem on my TC29. Called dealer and service tech. told me not to slam it closed. Just push down till it latches. Has worked every time since.
   / TC45 Hood Latch #6
Push DOWN on the top of the fiberglass hood as you pull the latch and I think it will fully unlatch and open. It works, Frank
30ft Highway Trailer Co. Lowboy (A56435)
30ft Highway...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56435)
Ditch Witch 6510A...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56435)
Midwestern...
flooring (A55758)
flooring (A55758)
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
