TC40DA Headlamp Assembly
   / TC40DA Headlamp Assembly #1
FritzWH
WA, United States
New Holland TC40DA, Cub Cadet GT2550
Just posted on the parts/repairs forum, cross posting here. My first day working with my new-to-me used tractor and I find a way to break the left side headlamp lens. Any ideas on parts sources? I should also be thinking about some sort of brush guard. :ashamed:
   / TC40DA Headlamp Assembly #2
Well, that's a $165 mistake for sure. Guard is a bit over $200, but may protect both lights. I love mine. With care, the guard works very well, but brush can still stick through it if turned right.
Does the guard work with a loader mounted? The diagram I found on the NH website was confusing - showed the whole assembly under "without loader" and under "with loader" it just showed mounting brackets with identical part number and appearance to the brackets in the "with loader" diagram.
   / TC40DA Headlamp Assembly #4
Yes, he grill guard works perfectly with a loader. The guard is hinged and has a latch. You unlatch the guard and tilt it forward so the hood can raise up. However, in the normal operating position, the loader does not even come close to the guard. The cross member between loader arms is several inches away at all times. It's a very nice guard for less than $225 and well worth it in my opinion.
   / TC40DA Headlamp Assembly #5
On some rigs like my Kubota even if you forget and left the guard in open position it would not interfere with loader bucket up and down movement. Jim, Is it the same with TC40?
Jc,
   / TC40DA Headlamp Assembly #6
No JC, if not latched, it will lay forward and hit the cross-member torque tube on the loader. It won't do damage, but will flop around rather unceremoniously.:D
   / TC40DA Headlamp Assembly #7
   / TC40DA Headlamp Assembly #8
Cool:) much better than Pow, Wham , Ka-pow !!:D:D Holy Grille Guard Batman!:laughing:
Thanks, Pedalstomper! The headlight is $17 cheaper than through my dealer, and the guard doesn't show up on the NH website, just tells me to call my dealer (and I never remember when they're open).
   / TC40DA Headlamp Assembly #10
The grill guard on my NH paid for itself on the second day I had the tractor. Was moving several long 4x4's using the bucket (didn't have my forks yet), laying them across the bucket top. Thought I had them leveled out OK, but a couple of them slid back off the bucket and banged right up against the grill. Rookie mistake, but the grill guard saved my bacon. ...and headlights and hood screen.
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2012 JOHN DEERE 310SJ BACKHOE (A52472)
2012 JOHN DEERE...
Towable Orchard Sprayer (A51691)
Towable Orchard...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
