TC40D tilt steering wheel repair
   / TC40D tilt steering wheel repair #1
GaryL54
New Holland
Thank you to previous members who answered previous posts in regard to a floppy steering wheel I have replaced the shock absorber in the column. The new cylinder however won’t compress enough to allow me to replace the screws to attach the steering wheel bracket. I have tried push in the little button at the end of the shaft and pushing on the new shock… no luck. Any ideas?
   / TC40D tilt steering wheel repair #2
Are you saying it won't compress far enough, or you can't compress it with one hand and start the screws with the other?
I had a similar problem on another tractor, same type of steering column shock absorber. I was able to push it in far enough, just couldn't keep it there long enough. I ended up pushing it in and tying it with wire. Then after install I cut and removed the wire. Worked for me.
Thank you for your reply! We installed the shock on the column and pried it down with a couple of punches to line it up with the steering wheel holes. We were able to line in it up and place the holding screws. All is great now!
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2015 Chevrolet...
2018 Toro Workman GTX Electric Utility Cart (A51691)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Sterling AT (A55301)
Club Car Utility Cart (A55851)
Club Car Utility...
