TC40D sighting
   / TC40D sighting #11
Didn't mean to scare you off. I guess I forgot to say how much I LUV my tractor even though I think I've had more than my share of "grief" with problems. I would not be afraid to buy another one. /forums/images/graemlins/grin.gif
   / TC40D sighting #12
</font><font color="blue" class="small">( Low-temp running due to flow bypass ....what's normal op temp? Can I expect to reach it in 15-20 minutes of checkout? )</font>
I was out at the farm today. It was 36 degrees and my TC40D's temperature reached operating range (middle of the temp gauge) in 10 minutes. Folks that have had problems wouldn't ever reach temp.
   / TC40D sighting #13
Jim (Jinman) and tc35dforme - with apologies, I'm stealing parts of your lists, and giving the main links that, for me, both describe and provide solutions for most of these "problems" with the Class III Boomers. Choreboy, every mechanical device can have problems, and every brand has them. I, like Jim, have never regretted my TC40D purchase.
1. Battery offgasing causing corrosion around battery and cooler. ( Some of us has gone to sealed batteries ala Optima )
Replacing the Battery on TC29D
batter terminal corrosion
2. No-joy joystick breaking at the screw hole for handle. ( New part engineered differently and fixes the problem )
No joy joystick
3. Low-temp running due to flow bypass at common coolant drain line. This problem happens because the Thermostat's "jiggle-pin" gets stuck in the thermostat, and the thermostat can never close. You can fix the thermostat (the cause), or clamp off the bypass hose (a fix that doesn't correct the cause)
Where the TC45D is not deluxe.
4. Coolant leak at fitting adjacent to oil filter ( Requires new part or reinstallation with high grade thread sealant )
A small leak Contains picture of replacement part.
small antifreeze puddle
5. Sticky/sluggish hydro pedals (clean, lube, and cautious operation seem to be the "cure").
HST pedal sticks under load
Follow-up to sticky hydro. pedals
6. Water getting into tilt-wheel mechanism/piston causing failure.
Frozen Tilt Steering on TC40D
7. Starter fuse (7.5 Amp) blowing, replacement is with an 8 Amp circuit breaker.
Blown Starting Circuit Fuse Thread includes part number for replacement circuit breaker.
8. Instrument panel fogging up. Mostly an annoyance, I don't recall any specific fix ever being proposed, other than replacing the insrument panel.
9. HST pedal plate inadequately welded (Jinman's Syndrome)
Where the TC45D is NOT deluxe
TC35D Pedal linkage busted.
   / TC40D sighting #14
Wait a minute....you added some !!!
Oh well, I still like my TC35D... maybe when I grow up I can get the extra cylinder /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
   / TC40D sighting
...Hain't skeered Mr I..., just writin' all this down as quik as I can!
Thanks Jinman for the assurance and Doc for the links.
I agree and understand:
" nothing mechanical is without it's problems" and I probably can handle most of these challenges should they show up...great to be able to ask for objective help, thanks again for takin' the time. I hope to check out that 40 on Saturday....
keep you posted
choreboy
   / TC40D sighting #16
Just a little note of clarification: Item 3 is really two separate problems (and cures) that both show up as a cool running engine. The first is the coolant drain line bypass problem - fixed by pinching off the drain line or getting NH's fix of a new drain connection at the block and lower fiting: and the second problem is the jiggle pin, fixed by either replacing or rigging the thermostat.
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
12in Backhoe Bucket (A52128)
12in Backhoe...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2015 Dodge 5500 4X4 Bucket Truck (A52128)
2015 Dodge 5500...
2008 BMW 528i Sedan (A50324)
2008 BMW 528i...
