TC40D jammed tilt steering
   / TC40D jammed tilt steering #11
If you have access to an air chisel gun with a drift or flat head bit that helps free up rusted fasteners. Soak it good with penetrating fluid and rat-a-tat-tat on the bolt head a few times. Back up the opposite side of the block with a heavy hammer to prevent deforming the housing.
   / TC40D jammed tilt steering #12
Sorry you are having problems. I can sure sympathize and empathize. It always seems it's not the job, but the things that don't work right that get you. If the impact wrench didn't work, you probably need some serious soaking with PB-Blaster or similar. Heat on the bracket and ice or freeze spray on the bolt head might also help. It occurs to me that the bolt might be part of what is holding your steering wheel firm also.:confused3:
NEVER USED FECON 74in Deck Mulcher FDM74 (A51039)
NEVER USED FECON...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
BLAST SHIELD (A50854)
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2012 Ford F-150 Crew Cab Pickup Truck (A49461)
2012 Ford F-150...
