TC40D hi/low switch
   / TC40D hi/low switch #1
NHWOODSMAN
New Hampshire
NH TC40D
While mowing the other day in real thick grass/hay the tractor decided to go from range 1 hi to 1 low all by itself. The "rabitt" light is still on. The light will go to turtle if I move the toggle switch or use the loader buttons but it still stays in low range or "turtle" despite what the light says. Any ideas... fuse, selenoid, major failure...?
Pat
   / TC40D hi/low switch #2
Pat, most likely you (actually somethng you drove over) pulled the wire off the solenoid under the left operator's platform. With the solenoid de-energized, the transmission always stays in Turtle. I've had this happen to me a couple of times. The fuse for this is Fuse #5, but if your lights are working for Rabbit, I suspect the fuse is okay. If this is not it, post back and I'll try to come up with another idea.
   / TC40D hi/low switch #3
This is what happened to TC45D #1 at 5 hours.
Try the fuse first.
If (when) that doesn't do it, it's the wiring harness.
Probably the fuse.
   / TC40D hi/low switch #4
Same thing happened to me once. The wire came unplugged just like Jinman said. As I recall, it was under the platform where your left foot goes.
Thanks jinman...it just came unplugged like you said.
Pat
   / TC40D hi/low switch #6
this has happen to be also. I also found the wires shorted out from rubbing aganist the switch so i repaired the wires and wraped a plastic wiring conduit around the wires.
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53473)
LIKE NEW 2023...
Genie GTH-844 (A50123)
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
2007 Chevrolet Tahoe SUV (A51694)
2007 Chevrolet...
