TC40D Glow Plug Problem
   / TC40D Glow Plug Problem #1
RandyV
In the morning when I go to start my New Holland TC40D the glow plug light does not come on. Since it is summer there is no problem starting the tractor. Later, after I have run the tractor a bit and shut it off, when I turn on the key the glow plug light and timer comes on and cycles normally. Is this a problem with the timer or does it mean that there is something wrong with one or more of the glow plugs? Thank you.
   / TC40D Glow Plug Problem #2
I suspect your timer bit the dust just as mine did. Here's the proceedure for checking out the timer it's pretty easy to do.
Mike, Thanks for the drawings, I will check out the timer today. What manual did those drawings come from? Looks like something that I should have. Randy
p.s. Checked out your site, Wow you have done a lot to your TC40 and the quality of the work looks fantastic.
   / TC40D Glow Plug Problem #4
Randy the diagrams are out of the NH repair manuals. I understand they are available in book style or on CD. I also believe that they can be purchased on-line.
Thanks for the compliment on the TC-40D pages. My hope is that they can help others that want to add accessories to their tractors as well. They seem to be pretty popular as they get lots of hits.
Mike, The problem seems to be a bad connection though I am not sure where. Everything is currently working fine and all that I really did is mess with the wires getting to the timer. We will see how it goes and thanks again for the information. Randy
   / TC40D Glow Plug Problem #6
Randy pull that Molex plug loose from the timer and check the connectors on both the pug itself and the timer module. Possibly there is a bit of corrosion starting there that might be causing your intermittent problem.
   / TC40D Glow Plug Problem #7
Randy,
I have a TC33D and I have experienced the exact same situation as you in the last week. Glow plug light does not come on when tractor is cold however, after it has warmed up it comes on with each turn of the key. Have you figured out what your problem was?
Tim
   / TC40D Glow Plug Problem #8
Many thanks to PineRidge. He did'nt realize it at the time but he was helping out more than one guy. Those pics showing location of glow plug timer were invaluable. Finally got around to replacing the timer & it works like a charm. A bit steep ($70 Canadian) for the timer but its worth it with this cold weather we have been getting up here. Don't even need block heater although I have one connected. Just fires right up after glow plugs time out. :)
Thanks Again,
Vic
   / TC40D Glow Plug Problem #9
So just how cold is it up there? We're shivering here in Missouri with nights in the teens and days in the 20's. We're just not used to this kind of cold - at least not for the past ten years or more. I'll bet it's a tad bit colder up in your neck of the woods!
KEG
   / TC40D Glow Plug Problem #10
Sounds like a corrosion problem; as things warm up ( expand0 and vibrate they make contact; shut off and cool down ( contract0 you loose contact. Time to pull ALL connectors on the circuit and clean very well; use dielectric grease in all connectors before reinstalling.
   / TC40D Glow Plug Problem #11
Thanks Again,
Vic
Vic glad to be of help. Our 40D refused to start once the weather turned cold until I finally made time to replace the timer. It now starts as it did when new.
Good luck to you.
   / TC40D Glow Plug Problem #12
To all, thanks for the discussion and helpful information. My TC40DA glow plug light was sporatically coming on during operation and this post prompted me to replace the timer. Problem cured! The attachments that Pineridge posted were extremely helpful.
Dealer had part in stock $61. 13mm and 8mm sockets w/long extensions and 20 minutes time (took the longest to figure out how to release the clip holding the connector into the timer with out breaking it)
Thanks again!!!!!!!
   / TC40D Glow Plug Problem #13
Thanks again!!!!!!!
Glad it worked out for you! Sharing knowledge & friendship is what this site is all about. :D
   / TC40D Glow Plug Problem #14
Stupid question of the day
Anyone know why the deluxe tractor glow plug timer times out in 5 or 6 seconds, and the ecomony models go 10 or 11 seconds? Aren't the deluxe and economy models just a trim level apart? I don't know the answer, just read about it in the first attatchment from Pineridge's post.
   / TC40D Glow Plug Problem #15
I guess NH figured time is a premium and the deluxe model should do things quicker. The deluxe model uses a quick heating glow plug (Y-701RS) while the economy tractors use a slower glow plug (Y-107V). Therefore, the timer is shorter for the deluxe model. Since it seems that deluxe model timers fail more than economy model timers, I guess NH also figures deluxe owners have more money to spend on repair parts.:rolleyes:;)
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
Classic 1969 Massey Ferguson 135, newly rebuilt engine, refurb front end, 3-pt blade.
Classic 1969...
2019 FORD F150 STX CREW CAB TRUCK (A59823)
2019 FORD F150 STX...
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
