TC40A shuttle shift failure/fix
   / TC40A shuttle shift failure/fix #1
nickel plate
CA
2002 New Holland TC40S
I was ripping my up my 4000 s.f. vegetable garden plot and on the last pass I shifted in reverse to clear the tines then back into forward-NO. The shuttle lever just softly wig-waged as in broken. I pulled the lower left hand side black plastic cowling underneath the lever and found a very important punch pin that connects the larger in diameter long lever shaft to the smaller in diameter transmission stub shaft laying neatly on top of the manual transmission. Disastrous condition but and easy fix. For further non-issues of pin rejection I wrapped the newly re-installed pin with a hose clamp. Tools: You will need a very long 1/2" socket extension to remove the two bolts inside the engine cowling by the muffler. Heads up.
2005 John Deere 200C LC Excavator (A59213)
2005 John Deere...
Miller Bobcat 250 Diesel Welder (A57453)
Miller Bobcat 250...
2021 CATERPILLAR 308 CR EXCAVATOR (A52709)
2021 CATERPILLAR...
2013 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52709)
2013 CATERPILLAR...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
WALKER 6" JOINTER (A58374)
WALKER 6" JOINTER...
