tc40a 3pt wont lift
   / tc40a 3pt wont lift #1
MAYOR8020
bath, ny steuben cty.
new holland tc 40a
Hello my 3 pt. wont lift while @ idle it will lift when you rev it up. The fel works as it should and so does the rear remotes. I have heard about a loose plug in the power beyond port. could someone please let me know a little more about this.
thank you
david:thumbsup:
   / tc40a 3pt wont lift #2
David, that plug in the power beyond port of your joystick valve would have an affect on both the 3PH and remotes equally. When you raise your 3PH to the top and shut off the engine, does the 3PH drop? My guess is that you have a leak in the lift cylinder or a problem with the HPL valve. I'll look for a thread about the power beyond plug, but I don't think that is your problem.
Here's a link to a post with a photo and illustration of the plug.
:thumbsup:Thank you i will get @ it this weekend. I will let you know how i made out. David
2013 Nissan Pathfinder SUV (A51694)
2013 Nissan...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
1982 LeeBoy Motor Grader (A53473)
1982 LeeBoy Motor...
90004 (A51694)
90004 (A51694)
