tc40 tach irratic
   / tc40 tach irratic #1
rubicon2
Louisville , ky
new Holland tc40d
Hey Guys. Tried the ag forum but no luck. I have a tc40d hrdrostat. All of a sudden the tach will not read until I reach about 2000 rpm. The needle is then a little wiggly but readable. Checked connection at gauge and alternator. Wires are tight. Any suggestions? Thanks.
   / tc40 tach irratic #2
I'm guessing your tach works using some sort of pickup or sensor that sends pulses from a notched wheel or magnet attached to the flywheel? Have you looked to see if anything is loose or bent down on that end of things?
   / tc40 tach irratic
I think it gets tach reading from alternator.
   / tc40 tach irratic #4
I think that's correct.
My tach is squirrely for 5-10 seconds every time I hose down the engine and radiator. Rain doesn't seem to have the same effect though.
2014 Ford Escape SE (A56859)
2014 Ford Escape...
2007 Homemade Pipe Trailer (A55973)
2007 Homemade Pipe...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
2005 GMC C7500 24FT BOX TRUCK (A58017)
2005 GMC C7500...
New Landhonor Gas Water Pump (A59000)
New Landhonor Gas...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
