TC40 steering problem
   / TC40 steering problem #1
Brikman
Louisville, KY
New Holland TC40
Changed out blown hydraulic steering hose. When put back together can't get no steering. Tried bleeding lines but no luck. Any ideas?
   / TC40 steering problem #2
Just the obvious maintenance checks is all that comes to mind. Is the reservoir full and have you changed the power steering filter? The service interval for my PS filter is 600 hours.
   / TC40 steering problem #3
You are aware that the power steering has it's own reservoir and does not use the hydraulic system of the tractor ......
   / TC40 steering problem #4
I don't know if this would help or not, but if it were mine I would jack up the front end so the wheels are off the ground (if you have a FEL, it should be able to lift the front) and run the wheel back and forth. Maybe even try to grab a front tire and turn it side to side.
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
Toro Workman Utility Cart (A51694)
Toro Workman...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
