Loader TC40 Questions
   / TC40 Questions #1
lively1
Madison County, Illinois - Near St. Louis
Kubota B2910
I am looking at purchasing a TC40 but want to make sure it will fit in my garage... What is the height of point where the ROPS fold down? I only have a 9x7 garage door.
Also does anyone have any experience mowing a lawn with this tractor with the 7.5' mower deck?
Thanks,
Troy
   / TC40 Questions #2
Troy, the ROPS folded is 77.5", and up it's 95". I don't know about the mower. You have about 35 power takeoff horsepower. So at 5 per foot, that equals 7'. You might bog down some in heavy grass.
   / TC40 Questions
It looks like with the ROPS folded down I will be able to fit into my garage... Thanks for the info
I just wonder how well this mower deck will work on standard lawn mowing. It is quite large. I am used to my 72" mmm on my B2910 which seems to work fairly well. I also wonder about the extra weight on the TC40 compared to the Kubota B2910? Too much weight on the lawn for a dedicated mower? Ideal scenario I would have a zero turn for the lawn and use the tractor for loader work, grass seeding (OS1548 and PS1572), aerating, and brush mowing. But budget does not allow.
   / TC40 Questions #4
I'm pondering doing the same thing....
Currently, I'm mowing with a 72" mower behind my dx33 case and having no problems with power. Even through higher grass.
   / TC40 Questions #5
I have a SQ172 6' cutter that I used on my TC40DA before I got the Boomer 8N. It worked well as long as I didn't go to fast in the really tall grass -3'-4'. For lawns a 7 1/2' should be fine as far as power goes. I bought a 6' finish mower but didn't like how it looks afterwards. If you use R4 or R1 tires it will damage the grass as the front tires slide in a turn. A wide cutter leaves the grass uneven as it hits high and low spots. I bought a zero turn and it works better for lawns.
   / TC40 Questions #7
I use R4 tires and have no problems with it tearing up the grass. Sounds like an alignment issue.
SKIDDED FUEL TANK (A55745)
SKIDDED FUEL TANK...
SOMERO S-222 LASER SCREED (A52707)
SOMERO S-222 LASER...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
