TC40 glow plug issue
   / TC40 glow plug issue #1
nyone
Veteran Member
Ford 851
Just got this tractor with 3,000hrs. The glow plug indicator light is lit all the time unless I disconnect the timer control box under the dash. Does anyone have a wire diagram or any helpful info about how to repair this?
Turn signals and flashers also dont work. Although the lamps do light when I jump power into the relay sockets.
   / TC40 glow plug issue #2
I hope theses will help with your issue.
  • Elec Schematics.pdf
  • Glow Plugs.pdf
  • Turn Signals.pdf
   / TC40 glow plug issue #3
My tc33 started doing the same thing a few years ago. I replaced the glow plug timer relay to fix the problem.
Thank you. I will check the schmetatics.
Thanks Thclimber I narrowed the issue down to the original NGK glow plug timer.
You dont have a digital copy of the service or owners manual do you?
   / TC40 glow plug issue #6
I had to replace my glow plug timer last fall and, in my case, a similar (much cheaper) P/N that supposedly cross-referenced did not perform properly. I tried to go with that at first, but ended up buying the expensive dealer part and that worked out. That's just my experience. I described this in detail here:
   / TC40 glow plug issue #7
When I did mine I think I used a Kubota relay I got off of eBay. Works perfectly and was much cheaper than the New Holland part from the dealer.
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2014 Ford C-Max Energi Hybrid Hatchback (A48082)
2014 Ford C-Max...
2017 Chevrolet Tahoe SUV (A48082)
2017 Chevrolet...
John Deere 2640A Tractor (A50860)
John Deere 2640A...
(6) Pipe Roller Stands (A50860)
(6) Pipe Roller...
