tc35d
   / tc35d #11
Jim, how about a waxy grease, like LPS 3, or something that doesn't attract so much dust. I haven't seen the problem with the sticking pedals, but I did spray some oil in the rollers.
   / tc35d #12
That might work, Duane. Actually, the last time I did it, I used chain lube. When it dries out, it leaves a dry lubricant, so I think it is similar to the waxy grease. The worst sticking I have had was in the first week I had my tractor and the forward pedal would stick like I had cruise turned on unless I stepped on the reverse pedal. Now, after 200+ hours, the pedal will sometimes just return slowly and that's when I get out my can of lube.
As you mentioned earlier, my tractor will creep if it's not on level ground. If I need to keep my bucket raised when I get off the tractor, I always set the parking brake or drop my boxblade if it is attached.
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2015 Freightliner Derrick Diger Truck (A55973)
2015 Freightliner...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Sterling AT (A56435)
