TC35D Throttle Inoperative
   / TC35D Throttle Inoperative #1
tc35dinsc
NH TC35D
2002 TC35D, 125 hours
When Throttle is advance, Engine RPM will increase. When throttle is moved back to idle position, Cable moves, but the Throttle arm on the Injector pump does not return to the idle position. Arm can be manually pushed back to idle position, but feels "stiff"
   / TC35D Throttle Inoperative #2
I'll check my Repair Manual tonight, but it sounds like you lost a return spring or need some lube in the area of the throttle.
Return spring is installed. Feels like plenty of tension. Where is the lubrication point for that shaft? Thanks John
   / TC35D Throttle Inoperative #4
I don't see any lubrication point, but the shaft attached to the throttle plate might have become corroded or have some other foreign material on it. I'd just spray some liquid lubricant on the shaft and behind the throttle plate to see if it will loosen up. If not, I think I'd talk to my dealer's service manager. He would probably know if the area is problematic. Mine (see attachment) works fine and doesn't bind at all.
   / TC35D Throttle Inoperative #5
One thing I forgot to mention...
The throttle assembly shown in my photo in the last post is actually mounted between the hydraulic pump and power steering pump, and is an input into the engine governor. The injector pump is located above the pump assembly. The throttle input to the governor must be binding. Has your tractor suddenly developed this problem or has it slowly gotten worse and worse?
It happened relatively quick
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 389...
6' BOX BLADE, 3PT (A52708)
6' BOX BLADE, 3PT...
2020 Hyundai Santa Fe SUV (A56859)
2020 Hyundai Santa...
2021 Caterpillar 308CR Midi Excavator (A55973)
2021 Caterpillar...
2020 MACK P164T (A58214)
2020 MACK P164T...
Skid Steer Concrete Mixing Bucket (New/Unused) (A59225)
Skid Steer...
