TC35D Start Circuit Diode
   / TC35D Start Circuit Diode #1
paccorti
Hillsboro Virginia (near Purcellville)
TC35D with 16LA Loader
My tractor has stopped starting unless I'm sitting in the seat. After some debugging I've determined the start circuit diode is bad (confirmed with multi-meter). It looks like it's NH part number 86512707. Has anyone found a substitute besides the NH part which costs $92 (for what appears to be a very simple electrical component)?
   / TC35D Start Circuit Diode #2
Does it have any other markings, numbers, or identification on it other than the P/N?
A good point, I should have scrutinized it more and looked. A guess many of these haven't gone bad. I'll go look at it more carefully and see if there is anything else on it.
   / TC35D Start Circuit Diode #4
I buy, maybe a hundred one amp diodes for a buck or so off E-Bay. Diodes really are cheap.
There are no switching speed issues in this application, and most start PRV around 50 volts which is plenty for a 12 volt system. Then, playing it safe, say pick a larger 10 amp one. No reason, you can't get that one diode for a buck!
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
1270 (A50490)
1270 (A50490)
