TC35D Start Circuit Diode
   / TC35D Start Circuit Diode #1
paccorti
Hillsboro Virginia (near Purcellville)
TC35D with 16LA Loader
My tractor has stopped starting unless I'm sitting in the seat. After some debugging I've determined the start circuit diode is bad (confirmed with multi-meter). It looks like it's NH part number 86512707. Has anyone found a substitute besides the NH part which costs $92 (for what appears to be a very simple electrical component)?
   / TC35D Start Circuit Diode #2
Does it have any other markings, numbers, or identification on it other than the P/N?
A good point, I should have scrutinized it more and looked. A guess many of these haven't gone bad. I'll go look at it more carefully and see if there is anything else on it.
   / TC35D Start Circuit Diode #4
I buy, maybe a hundred one amp diodes for a buck or so off E-Bay. Diodes really are cheap.
There are no switching speed issues in this application, and most start PRV around 50 volts which is plenty for a 12 volt system. Then, playing it safe, say pick a larger 10 amp one. No reason, you can't get that one diode for a buck!
John Deere Gator XUV560S4 4x4 Utility Cart (A50322)
John Deere Gator...
2020 KENWORTH T680 SLEEPER TRUCK (A52141)
2020 KENWORTH T680...
2006 John Deere 6320 (A50120)
2006 John Deere...
Bobcat Skidloader PHD (A50774)
Bobcat Skidloader...
P.T 14' Disc Harrow (A50120)
P.T 14' Disc...
Hydraulic Power Unit S/A Towable Pump (A50322)
Hydraulic Power...
