TC35D power beyond not working
   / TC35D power beyond not working #1
Fuzzy711
NH tc35d
We have a TC35D w/757c BH and 16la FEL. The problem we have is no pressure to the power beyond. BH was working and we removed it to use the 3PT, once we figured how to hook up the power beyond the 3pt worked fine. Used the 3pt with a drag blade several days with no problems, took a break one day and set the blade down, when I came back tried to rise the blade and it wouldn't come up. After some work we were able to put BH back on and still no power. Any idears, there is flow but no pressure. We are the 3rd owners of this tractor, the 2nd owner never had the BH off.
   / TC35D power beyond not working #2
Are you sure all the hoses are fully seated? Sometimes they can look seated but not really be. They do not always connect fully if the pressure has not been relieved before plugging them back together.
   / TC35D power beyond not working #3
I also say to make sure all the quick connects are made. I'd disconnect and reconnect each one to be sure, then give a good tug to make sure they are connected.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2019 Freightliner M2 106 Johnston VT651 8.5 Yard Street Sweeper Truck (A56858)
2019 Freightliner...
