tc35d no power after heating glow plug
   / tc35d no power after heating glow plug #1
tonyiver
Hello, need some help, I have power when I am heating up the glow plug but once I turn the key to start the tractor I hear a click and i lose all power. after a while it resets itself and it do it again and the samething happens again. check the battery voltage and I get about 12.4 volts. sounds like a relay tripping. where are the relays located? I have the same thing happen in the winter and found out it was a bad battery. the battery is oly a couple years old and I alway take the battery out for the winter. thanks for any help.
Tony,
   / tc35d no power after heating glow plug #2
You need to do a load test on battery. I use a carnon pyle tester myself, but just take battery to napa or likewise and have it tested. 12.4 means nothing.
Another good trst is to have someone hold a tester to battery while you try turning it over.
Thanks for the input, I will be getting my dads load tester. I have had the same problem with this Oem battery, it does not say new holland like the original, I asked the dealer and they said that is what they are putting in as a replacement, this is the second one I've had.
Tony
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
New Holland LB75B (A51573)
New Holland LB75B...
1973 TANDEM AXLE DUMP TRUCK (A52576)
1973 TANDEM AXLE...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A52748)
Quick Attach Skid...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52748)
Gooseneck...
