TC35D No electrical
   / TC35D No electrical #1
tractorblue
Van Alstyne, TX
New Holland TC35D
Turn the ignition key (checked good with meter) and get NO lights on the instrument panel. Fuel solenoid will not engage because its not getting power. Battery checks good, 40amp main fuse good, all 7 fuses good, seat safety switch by-passed, PTO safety switch by-passed. 12 volts at the main fuse block. Cleaned and tightened battery posts and ground lug. Dead as door knob. What am I missing?
   / TC35D No electrical #2
Your getting 12v out of the ignition?
SOLVED: i had cleaned battery post and ground connection. BUT it was the red positive cable wires that were corroded underneath the terminal lugs. Took a power drill and wire brush and cleaned the wires and terminal lugs connection. Its the simple things that are often overlooked; even though I had previously tightened the terminal lugs.
   / TC35D No electrical #4
God to know you got it running... Just keep an eye on both the positive & negative cables, the NH TC's cables are known to have internal corrosion issues & cause all sorts of issues.
   / TC35D No electrical #5
Harbor Freight sells a dandy battery terminal cleaner for under 5 bucks. A must for every tool box...
   / TC35D No electrical #6
Gotta love those quick find and fix. :)
   / TC35D No electrical #7
The battery is in a spot on these that can get wet when it rains. Not the worst thing but can cause issues.
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
1988 KENWORTH T800 DUMP TRUCK (A57192)
1988 KENWORTH T800...
2018 Ford F-150 Crew Cab Pickup Truck (A53422)
2018 Ford F-150...
TANK MANIFOLD (A58214)
10' CONTAINER (A52706)
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
