felixedo
- Joined
- Jul 15, 2011
- Messages
- 50
- Location
- Missouri Ozarks
- Tractor
- New Holland TC35D / Deere 1026R / Bobcat CT2040
About a year I took my 2002 TC35D to a local Kubota dealer to have some minor work done. The nearest NH dealer is over an hour away, and I figured they could handle it. For the most part, they did. Except that the ignition switch failed while in their possession, so they installed a Kubota switch. It basically works, but it's junk. The biggest problem with it being that the key is not locked into place when on. I have already lost a key in the field. Fortunately, I had a spare key to shut down the machine. The other problem is that it is a 4 position switch (ACC / OFF / RUN / START), and the original had a 3 position (OFF / RUN / START). I would like to go back to an original style switch. -current p/n 86405634
The issues: The OEM switch is set up for a proprietary 4 prong connector that was cut when the Kubota switch was installed. "Why don't you just buy the connector and splice it into the line again?" you ask. The connector p/n is not identified as a standalone piece. It is only a component of the wiring harness which sells for $1000.
Finally, the questions. Any 1 answered will get me moving forward:
-Does anyone have an idea of the part number for the harness end of the switch connector?
-Alternatively, can anyone tell me particular post labels (A,B,C,D) for the OEM switch? They are not labeled on the switch themselves.
-Can anyone identify for me which wire goes to which post?
-Can anyone identify a comparable 3 position, 4 post key switch that would be a suitable alternative? The most common aftermarket switches are only 15 amp and 3 poles that I don't think could handle the load. 4 position switches are more common.
Thanks in advance.
Thanks in advance.
