TC35D joystick problem
   / TC35D joystick problem #1
BigOaks
North Carolina
TC35D New Holland
After recently getting my broken joystick replaced on my TC35D under warranty, I decided to purchase an extra just to have on hand because my dealers are so far away. I purchased a new metal shaft, New Holland Part #86400437 which was $24.08 plus tax. I figured it will probably break again when I need it most, so having one on hand can`t hurt. New. Holland engineers really messed up when designing /forums/images/graemlins/mad.gifthis one!
   / TC35D joystick problem #2
Since you've spent almost $25 already, I think I'd take the new part down to my local welding shop and see if they could "beef up" the extension that is prone to breaking. If you explain the problem, I'm sure even a rookie welder could come up with a better design than the stock NH part. I hate that you had to buy an extra part, but you'd hate it a lot more if you replaced the broken joystick and it broke yet again. /forums/images/graemlins/shocked.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/mad.gif
   / TC35D joystick problem #3
Does any body know if this problem exist on the TC29D also? If so I will go out and get on fixed up also. I have a 7308 loader with a joystick.
Murph
I believe the problem is only with the new deluxe joystick that is orange and black in color. It also contains the hi-lo switch aka rabbit /turtle switch which is encompassed within it. The poor design is on the metal shaft which is screwed together with two screws from the outside. When the joystick gets a lot of usage stress is created at the upper screw causing it to break. I do not weld, but I am sure " beefing" it up wouldnt hurt. /forums/images/graemlins/wink.gif
   / TC35D joystick problem #5
Then I should be ok. Great
Thanks
Murph
   / TC35D joystick problem #6
Hi all,
I just went through the replacement process, and figured why replace it with something that will only break at the worst possible time. I figured I could do a better job at a replacement, So-- I went to the local hardware store and matched up some all thread 7/16" x20 thread, and small 4" long pipe and made my new one. I took the piece of pipe and welded the nut which matched the all-thread that I used. I then drilled three holes in the pipe. I matched the holes from the joystick handle and drilled the pipe. I also drilled a hole in the pipe near the bottom, to pass the control cable through the pipe. (I needed to cut the control cable at the bottom to make it small enough to pass through the pipe. I then soldered it back together once it was fed through the pipe.) I then drilled the joysick holes all the way through the other side. After bending the all-thread to match the original part, it turned out great. The joystick is now attached to a complete piece of pipe, with two 1/4" nuts/bolts. Although I made two of them, since I had the material, I doubt that it will EVER break!!
   / TC35D joystick problem #7
Any possibility of a picture?
I'm just waiting for mine to break....
Mark
Never Mind - just found the pics under the "no-joy joystick" thread... /forums/images/graemlins/blush.gif
   / TC35D joystick problem #8
markie61,
Check out the 3 posts that I did on the "no joy joystick" title. It has pictures. Good Luck.
   / TC35D joystick problem #9
A mechanic\'s view
Here's my take on the "No Joy Joystick".
Is the part underdesigned? Definitely.
Will everyone have a problem? No.
At least 90% of owners hav no trouble with the Deluxe joystick. Those that do have breakage are almost guaranteed to continue to have failures because the part can't handle the heavy handed tactics of some operators. These parts were recently on 'backorder' due to demand. We took a couple broken ones and welded them back together, completely filling the lower screw hole with weld. None of these has failed (yet). Of course, we are relying on only one screw to hold the handle. Clearly, a redesign is in order.
AGRICO FERTILIZER SIGN (A58374)
AGRICO FERTILIZER...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
2017 Komatsu WA500-8 Wheel Loader, S/N A96097, PIN# KMTWA134LGNA96097, Komatsu Turbo Diesel Engine, (A59076)
2017 Komatsu...
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A52709)
2019 KOMATSU...
LOT: Tap & Die Set, Hole Saw Set, Snap Ring Plier Set (A59076)
LOT: Tap & Die...
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
