TC35D fluid cooler repair question
   / TC35D fluid cooler repair question #1
LabLuvR
SC
Kubota MX5400
The fluid cooler that sits directly in front of the radiator is leaking. I'm not much of a mechanic, can anyone tell me how hard it is to replace that cooler? Also, why would the cooler have a leak when the tractor only has 650 hours? How does one clean the gunk off the radiator from the fluid leak?Thanks!
   / TC35D fluid cooler repair question #2
I have a friend that developed a leak in the hydro cooler on his 35D, in fact, I think it happened twice. I'll ask him tomorrow.
Pretty sure I've seen a thread on this before so you might search for this issue.
As for cleaning the mess up, I use a little Dawn dish soap in a garden sprayer then flush with the hose. If it works to clean oil covered waterfowl, it can't be to hard on the tractor. :)
Thanks! I did do a search and found about everything I needed. It looks easy enough to install.
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2019 FREIGHTLINER M2 26' BOX TRUCK (A51247)
2019 FREIGHTLINER...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
Case SV185 Compact Wheel Loader Skid Steer (A51691)
Case SV185 Compact...
