TC35A Clutch Issues
   / TC35A Clutch Issues #1
hayesdt87
Pickens, SC
2007 New Holland TC35A
I just bought a 2007 TC35A with 620 hours. I put about an additional five hours on the tractor and started having what I believe are clutch issues. The tractor pulls fine in lower gears but in higher gears loses power up hills or won't move at all on flat ground in top gear. I'm considering splitting the tractor on my own to save money but I don't want to get in over my head either. It also seems odd for a tractor with so few hours to be having clutch issues even with the FEL. The tractor otherwise is in great shape. All the fluids are clean and I've checked the clutch linkages. Any thoughts would be appreciated.
Also a New Holland clutch is twice what an aftermarket clutch from my local dealer cost. Is there that much difference in quality?
   / TC35A Clutch Issues #2
I've got a 2005 TC48DA with the same problem. Last year i was able to adjust the clutch linkage underneath to help solve the problem. Service techs told me the clutch was not releasing all the way causing it to slip.
Now, the linkage is fully extended and I have no more adjustments. I am assuming that my clutch plate is shot. Seems like i can get a replacement for under $200 on ebay but im not sure what the labor is going to cost me.
Runs great in low, 1-4. Sometimes i can move along min mid range, but the slightest incline brings it to a stop.
2007 GMC 2500HD (A56435)
2007 GMC 2500HD...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-150...
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
TANK MANIFOLD (A58214)
2018 KENWORTH T800 HOTOILER (A58214)
2018 KENWORTH T800...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56435)
2014 Doyle Dry...
