TC35 Tachometer Failure
   / TC35 Tachometer Failure #11
I have a TC33 (base model). The name plate on mine says MODEL and below it shows TC33S. I assume 3H19D is the Model for your unit. Since they were manufactured in japan, there may have been several different companies who plated the same basic tractor.
I just purchased my TC33 this week. It is rough, but workable for my situation. It has the 7308 loader and a very old blade on the rear 3 point connection. The previous owner had not used the tractor very often, only for gravel drive maintenance.
Some how when I tested the tractor I missed that the Tach was not working correctly. It never exceeds 800 rpm on the tach. I know it is running faster, but don't know what the actual RPM is. The hour meter is working (saw it click over this morning). I assume I will have to replace the tach, since the hour meter is working. I will need a working tach, since I plan on mowing with the unit. Any input?
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
Peterbilt (A51692)
Peterbilt (A51692)
Kubota M5-111 (A53317)
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
