tc33da
   / tc33da #1
gfwireman
rear pto output shaft moves back and forth, resulting in a huge oil leak any thoughts?
   / tc33da #2
Quick! Get a drip pan!:eek:
Is that the thought you were looking for?:D
Seriously, it sounds as if your bearing and seal are gone. This could be caused by a bent PTO shaft. The wobbling shaft would cause severe side loads and eventual wear leading to failure. Whatever the reason, I don't think it's a terribly expensive repair. Good luck and please let us hear what the outcome is.
I hope you don't take offense at my having some fun with your question. If so, sorry.:eek:
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
1266 (A50490)
1266 (A50490)
2015 Ford Transit 250 Cargo Van (A51692)
2015 Ford Transit...
2016 Kenworth T880 Tri-Axle Brenner Fuel Tanker Truck (A51692)
2016 Kenworth T880...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
