TC33DA won't turn over or start
   / TC33DA won't turn over or start #1
Wanderer
Never ends..
Just turned off the tractor. Hopped off. Hopped back on 20 minutes later and it will not turn over. Acts just like a kill switch is stuck. Any thoughts on where to start looking or troubleshoot the kill switches?
Found it. Number 2 fuse (10) blown.
   / TC33DA won't turn over or start #4
That's why you should replace that fuse with a circuit breaker. Known issue. If the battery is just a little weak, too many amps are pulled and the fuse blows.:)
   / TC33DA won't turn over or start #5
On the Class III Deluxe tractors we have a PTO light that comes on even though the PTO is not engaged. That's a sure sign that fuse #2 is blown. I don't know if you have anything like that on the Class II TC33DA, but it sure is handy to have something that is a hint like the PTO light.
As MikePA suggested, the self-resetting circuit breaker is the ultimate cure for this known intermittent problem.
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2016 FREIGHTLINER...
2015 Ford F-750 Liftmoore 2550 5,000LB 2.5 Ton Crane Mechanics Truck (A51692)
2015 Ford F-750...
2005 Honda Foreman 420 (A50123)
2005 Honda Foreman...
