TC33DA hydraulic leak - how expensive will this be?
   / TC33DA hydraulic leak - how expensive will this be? #1
adlertom
Southern Wisconsin
New Holland TC33DA hydro w/supersteer
I noticed some seepage on the underside of my TC33DA. Photo attached. The top left bolt shown in the photo was slightly loose, and I tightened it by about 1/8 of a turn. The other bolts (at least the ones that I can see and get to) are all tight. Tightening this bolt reduced, but did not eliminate the leak.
Hydraulic fluid level is OK, and I think I noticed it early. I don't seem be losing very much fluid fortunately.
I assume that there is a seal between these two housing sections? If so, is that the likely issue? It looks like it would be a big job to take all of that apart.
The tractor is 20 years old, so maybe these sorts of things are going to start happening. Only about 650 hours however.
   / TC33DA hydraulic leak - how expensive will this be? #2
No gasket between the housings. Originally used sealant when bolted together. If all the other bolts are tight, then chances are it will keep seeping.
The tractor would have to be split there, sealant applied and the halves bolted back.
Clean that area up with parts cleaner or starting fluid and keep an eye on the leak. May be you caught it or it is something else.
   / TC33DA hydraulic leak - how expensive will this be? #4
Good advise on above. Keep it clean and check regularly. Want to go a step further to pinpoint add an additive to hydraulic oil so you can black light it.
Had a similar situation on my NH but when new. Leaked slightly in a banjo connection area. Cleaned, replaced seals, cleaned up mating surfaces. Did everything. Then went the last step and replaced the line. Turns out that was the issue and had I somehow done something different when I first noticed the leak the parts could have been under warranty but because it was new it couldn't be the line, it had to be the connection.
Definitely clean it up real good and keep an eye on it as @TractorTech suggests. I would be VERY suspicious of the banjo bolt connector nearby.
I'm not familiar with how banjo bolt connectors work - just read about them however. Pretty neat.
Could I try tightening that, or is there a torque limit or risk of damage that I would need to be cautious about?
   / TC33DA hydraulic leak - how expensive will this be? #6
A banjo bolt is essentially a hollow bolt with a hole drilled across the diameter to allow oil flow through it. Copper crush washers, typically, seal either side of the banjo. Nicks in the sealing surface of the banjo or bolt will allow oil to leak and the washer can't seal.
The bolt can be broken from overtorqueing, so be careful tightening it. "Tighten" the bolt to see ifvit is loose. Otherwise, you can remove the bolt to inspect the washers or banjo for nicks.
Lastly, order the washers and replace to see if the leak goes away
   / TC33DA hydraulic leak - how expensive will this be? #7
Can you determine the rate of fluid loss?
How much per hour operating/non-operating?
I've never see it actively "drip" and the hydraulic fluid reservoir dipstick shows full. It's more of a seepage.
I suspect that it might only be seeping during operation, and that it doesn't actively seep when the tractor is off/parked.
   / TC33DA hydraulic leak - how expensive will this be? #9
I always say that hydraulic oil is like blood; a little makes a big mess!
   / TC33DA hydraulic leak - how expensive will this be? #10
If it is just sweating and not dripping, I wouldn’t mess with it after tightening bolts.
   / TC33DA hydraulic leak - how expensive will this be? #11
You might look up higher on your tractor and see if the oil is running down there. Under the seat there are some fittings that can leak and make it look like it is from down lower. It’s much easier and less dollars to fix.
I remember seeing a thread about it here.
   / TC33DA hydraulic leak - how expensive will this be? #12
I also have a leak(significant), The problem is isolating it. I used the black light method, but when I viewed it, the leaked material was everywhere, more toward the Right side(yes, I did clean with solvent first). I cannot reach the fittings under the tractor(the area located below the seat "area") without removing the rear tire. Also, even with flashlight, my poor eyes cannot detail that distance. However, I will add my focus to the area of the bolt (just in case). Fixing is one matter (fix yourself or hire it done), diagnosing is more critical, but it all can umbrella under the same frustration. A learning experience. new holland,2005,tc45DA
   / TC33DA hydraulic leak - how expensive will this be? #13
In that case I'd just monitor it and park it so drips don't cause a problem.
Yes, I would like to check higher up. It's difficult to access that area however. Looks like the easiest way might be to remove one of the rear tires and reach in from the side?
Besides any fittings or other "fluid holding" items, are there housing bolts on the top side, similar to the ones I can see and get to on the bottom side? If so, I'd like to check the tightness of those.
I can (barely) get to bolts about half way up, inserted from the opposite direction, and those seem tight.
   / TC33DA hydraulic leak - how expensive will this be? #15
Mine is also 20 years old although not a NH, like yours it had been seeping hydraulic fluid for a while. Turns out it was a slightly cracked hose for the power steering. The mechanic who serviced it told me it took longer cleaning up the machine to locate the leak than to actually fix it.
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
M998 (A55852)
M998 (A55852)
2013 HAM 289I-30 8 WHEEL PNEUMATIC ROLLER (A60429)
2013 HAM 289I-30 8...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
UNUSED FUTURE...
