TC33D screeching sound in FWD
   / TC33D screeching sound in FWD #1
TO30
Oconto Falls Wi
New Holland TC33D
Last week I purchased, from a dealer in WI, a TC33D with 1172 hours. Upon putting into FWD it makes a screeching sound when stepping on the HST forward pedal. Has any one else experienced this problem?
   / TC33D screeching sound in FWD #2
Try greasing front driveshaft shield.
Thanks for the reply: I did grease that very well. When I go out after lunch I will give it another shot. The screeching sound is coming from the rear of the engine. This afternoon I will change the transmission / hydraulic oil and filters. It is 1343 hours past do. So much for buying a used tractor from a dealer that told me it was in excellent operating condition. Also the differential gear for the front wheel drive is totally dry. I will also fill that as well.
I am 66 yrs old, retired, two children, 5 grandchildren, and a loving wife of 44 years, and no animals with a 160 acre tree farm of red pine with the first stands planted in 1959 as my brother Billy and I rode the planter.
   / TC33D screeching sound in FWD #4
Give it another 10-15 shots.
I gave the booted drive joints 4 good pumps of the grease gun and filled the front differential with NH-134. The screeching has disappeared. Thanks for the help!
   / TC33D screeching sound in FWD #6
Just joined the site. Who would have thought a driveshaft shield could make that kind of racket!
Thank you very much for the tip, its as quiet as could be now! I thought I was in for a big repair.
   / TC33D screeching sound in FWD #7
Hello, I own a 2001 TC29D. I've dealt with the hydraulics screeching when cold (<40) for a long time. At 250hrs I replaced my hydraulic fluid with Kubota UDT. It still squealed but not near as bad. This fall I reached 1000Hrs and I replaced the filters and refilled with Kubota Super UDT II. So far No squeal at all. And it's cold here in Michigan right now. Al>
2016 Ford F-150 Crew Cab Pickup Truck (A53422)
2016 Ford F-150...
Cummins 6-Cylinder Diesel Engine with Transmission (A55852)
Cummins 6-Cylinder...
2017 Rockwood Esp Pop Up Camper (A51694)
2017 Rockwood Esp...
2013 Cheverolet Impala 1FL Sedan (A55853)
2013 Cheverolet...
Mini Metal Donkey Statue (A55853)
Mini Metal Donkey...
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
