TC33D screeching sound in FWD
   / TC33D screeching sound in FWD #1
TO30
Oconto Falls Wi
New Holland TC33D
Last week I purchased, from a dealer in WI, a TC33D with 1172 hours. Upon putting into FWD it makes a screeching sound when stepping on the HST forward pedal. Has any one else experienced this problem?
   / TC33D screeching sound in FWD #2
Try greasing front driveshaft shield.
Thanks for the reply: I did grease that very well. When I go out after lunch I will give it another shot. The screeching sound is coming from the rear of the engine. This afternoon I will change the transmission / hydraulic oil and filters. It is 1343 hours past do. So much for buying a used tractor from a dealer that told me it was in excellent operating condition. Also the differential gear for the front wheel drive is totally dry. I will also fill that as well.
I am 66 yrs old, retired, two children, 5 grandchildren, and a loving wife of 44 years, and no animals with a 160 acre tree farm of red pine with the first stands planted in 1959 as my brother Billy and I rode the planter.
   / TC33D screeching sound in FWD #4
Give it another 10-15 shots.
I gave the booted drive joints 4 good pumps of the grease gun and filled the front differential with NH-134. The screeching has disappeared. Thanks for the help!
   / TC33D screeching sound in FWD #6
Just joined the site. Who would have thought a driveshaft shield could make that kind of racket!
Thank you very much for the tip, its as quiet as could be now! I thought I was in for a big repair.
   / TC33D screeching sound in FWD #7
Hello, I own a 2001 TC29D. I've dealt with the hydraulics screeching when cold (<40) for a long time. At 250hrs I replaced my hydraulic fluid with Kubota UDT. It still squealed but not near as bad. This fall I reached 1000Hrs and I replaced the filters and refilled with Kubota Super UDT II. So far No squeal at all. And it's cold here in Michigan right now. Al>
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52748)
2024 Ford F-350...
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2012 Harley-Davidson FLHX Street Glide Motorcycle (A50324)
2012...
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
Set of Ag R4 Wheels and Tires (A52748)
Set of Ag R4...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
