TC33D Narrow WheelBase
   / TC33D Narrow WheelBase #1
Anonymous Poster
Epic Contributor
I just took delivery of my new tractor, and I noticed how narrow the wheels are set . Does flipping them really improve it much or is it a waste of time? My 9n is much wider/ more stabile.
   / TC33D Narrow WheelBase #2
Assuming you have Ag tires, you can flip them (actually, swap sides to keep the tread correct). I'm not sure how much you will gain, since I can't get out and look at my TC33 tonight, but it does make a difference. Most people I know leave them set wide, unless they have space concerns like driving through tight trails in the woods. You can get an estimate of how much further out they'll go by looking at how offset the hub of the wheel is from the centerline of the tire (while you are looking, you can make sure yours are not already set to the wider position).
John
NOTE: if you have filled rear tires, swapping them is not something to be taken on without the right equipment. They are heavy and unwieldly. Use caution if you are doing it yourself.
Thanks John, I'm gonna try and change the tires around. Yes they are filled, so I guess they'll be a bit heavy. I plan on jacking up the rear with a buddy and swaping them around. then I guess I could use the front bucket to raise the front ones and make the swap. I'd just feel a bit better if I had a little wider track.....
Sean
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2225EB000634, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
2015 Chevrolet Silverado (A56858)
2015 Chevrolet...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
BUSH HOG DISC (A58214)
