TC33D loss pf power when going up hill
   / TC33D loss pf power when going up hill
The part I disconnected I thought was the solenoid shut off arm.
   / TC33D loss pf power when going up hill #13
The solenoid is at the rear of the pump and directly contacts but is not connected to the fuel rack. The governor linkage goes into the governor which is located in the timing cover. If you had the barrels out of the pump housing you are screwed. They need to be installed then adjusted on a test stand.
Power problem seems to be resolved. After 3/4 of a tank of fuel with Lucas injector cleaner a new fuel filter and air filter everything seems to be much better.
I will provide another update after I get it in the field.
Thanks for all the assitance.
   / TC33D loss pf power when going up hill #15
Nice, sounds you lucked out then!
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2013 Ford F450 Flatbed (A55973)
2013 Ford F450...
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2007 Hyundai Santa Fe SUV (A55973)
2007 Hyundai Santa...
